UBC 220xlt modaaminen
Beagle
Oliko kellään tallessa UBC 220xlt:hen mitään modausohjeita. Muistelen että skannerilehen foorumilla oli aikoinaan paljonkin juttua ko. laitteesta. Eniten kiinnostaisi onko mahdollista lisätä äänenvoimakkuutta isommalle kaiutinta vaihtamalla tai muuten? Lisäkaiuttimella kokeilin eikä se oikeastaan lisää ääntä millään tavalla. Kaikki vinkit ja parannukset on tervettulutta. Hyvä laite tuo on nykypäivänäkin.
Ei tukiasemaa käytössä toistaiseksi, Työajokissa Mocoma 59s. ch: 19am/7FM, UBC BCT15x
Re: UBC 220xlt modaaminen
Tämä nyt ei ehkä ole mitä haet..
Tuosta kuvien kera http://gzt.fi/radio/Displaylight_modifi ... 220XLT.pdfDisplay light modif. for handheld scanner model Uniden UBC220XLT (will probadly be the same for UBC120XLT, UBC235XLT etc.).
This modif. will do the following to the above scanner:
When charger/DC-supply is connected and the scanner is ON, the display light will come on and remain on, as long as a DC-Source is connected.
When no charger/DC-supply is connected the display light will function as the scanner is standard (15 sec. when light button is pressed).
This gives the following advantages over the standard light function:
When scanner is used on battery (portable) the lightfunction is as standard. When standing on the shelf at home with charger connected, the display light will be ON, so frequency/channel can easier been seen.
Cost for this modif: ~0,50 Euro (1 BC547C or equiv + 1 resistor)
Skill: Some electronic skill is required (soldering on small components)
Required tools: Philips skrewdrivers, small solder iron, a piece of small wire.
Warranty: Your warranty will be lost. Modification is done on your own risk.
A handy hidden feature in the BC220XLT, is an indicator of the amount of charge left in the NiCd battery pack.
The DATA and MANUAL keys are hold down while powering on the radio to access this feature. Once accessed, this feature displays a number somewhere between 1,4 and 1,7. 1,4 means the pack is nearly empty, and 1,7 indicates a full charge.
This is a great feature for determining whether the pack is full or nearly empty.
It also works for the BC-120XLT scanner.
Beagle
Kiitos! Tuotakin ominaisuutta olen kaivannut että saisi valot pysymään päällä. Tuopa täytyy kokeilla tehdä!
Beagle
Tein tosiaankin tuon valot päälle modin, siten että vedin suoraan runkoon johdon tuolta piirikortilta, näin ollen valot palavat kokoajan päällä. Näin se saa ollakin, koska käyttö on pääasiassa autokäyttöä ja tupakansytkästä tulee virta.
Samalla kun kapula oli levällään pöydällä, avarsin 3mm terällä etukuoren kaiuttimen reikiä isommiksi, huomattavasti kovemmin tulee nyt ääni.
Hyvä jos oli apua, enempää ei löydy takataskusta ideoita/modiksia lähteistäni, jossain oli jotain juttua et tuosta ois 2 eri versiota (EU/USA) missä olis eri taajuudet ja ne saisi molemmat laajennettua kyl kaikille, mutten löytäny pienellä etsimisellä sitten mitään ohjetta/modista asiaan et liekö faktaa vai fiktiota?..
